Is anybody running the ascendant smdv2 18
Noflex
15s only require 3-4 cubic feet tops.
The 15's I could work with I need to be under 12 cubic feet to fit my batteries an amp rack... My hole goal is to be able to pull hair tricks at the local car shows will 2 fi-sp4 15's be able to do that?
Yes on 6-7k watts 2 sp4 15's should pull a hair trick if you are tuned low and have lots of port with a bigger box like 8 cubes or so. Id say get a dual alt kit with 2 hairpin alts for your chevy, biggest battery under hood then 1 or 2 in the rear and that should have no trouble fitting. Measure the length, width, and height of the rear of your vehicle and account for the humps and leave a few inches under the window line to account for subwoofer excursion that could go over the window line.
I built the floor up an made a deck out of 2x4 an birch to have a flat platform with the batteries underneath mounted to the floor the amp rack an subs will be on top an I have a dual alternator kit with 2 mechman 370+ alternators an 4 xs batteries an a upgraded alternator an battery for my mids an highs an to power the rest of my truck power should be good on that end I have custom door panels that I made with 4 Skar audio pax 6.5 an 1 ix-8 an two super tweeters in the front doors Ima make a build thread as soon as I figure out what to do for subs but I'm prob gonna go with 2 sp4-15's
To be honest its worth the wait
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
You'll be fine with that electrical.. I read that you have a 60 x 30 x 30 to work with so id just make the box around 50w x 20d x 15h which gives you over 8 cubes to work with.. you could either do a center port and fire off a center console or a side port and fire off a door.
Id get a a solid amp like the Dc 7.5k or maybe an ampere TFE to pair with 2 sp4s. You will have box rise and and the sp4s have 4 inch coils so they can take the power.
I've heard there really good subs I think that's what Ima go with 2 sp4-15's
It's what I was going to do at one point but I ended up getting 4 12' AA Havocs.
I was unsure about port didn't know witch would be best for my vehicle since I'll be against the back was thinking port up so it would channel air threw the hole cab instead of a midway point or threw the center of the seats an I would love to do 4 subs just don't have the room for everything without building a wall an putting batteries an amps in the bed
Side ports are usually loudest in extended cabs. Port up works as well. 4 12's takes up the same space as 2 15's. The box for my 4 12's will be around 6 cubes or so.
  • Who's Online   0 Members, 0 Anonymous, 1755 Guests (See full list)
