wiring an aftermarket radio in 03 impala
Alot of times that red wire has to be tapped into a ignition source. People sometimes tap into thing like the cigarette lighter. The correct harness typically costs about 60-100 bucks and retains chimes/has a accesory wire built into it.
1999 Lexus GS 300
Pioneer DEH-80PRS
Singer 240 Amp (Will be installed later)
Northstar Group 31 & 24
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds 6.5 Meso Components
CT Sounds Tropo 6.5
look for pac rp3-gm11 if you don't have bose or pac rp5-gm11 if you do. The rp5 also comes with steering wheel control adapters as well as an antenna adapter
1999 Lexus GS 300
Pioneer DEH-80PRS
Sundown SCV-4000
Rockford T400-4
2 12" CT Sound Meso
CT Sounds Tropo 6.5
Most people use a add a circuit and tap into any fuse that turns off with the vehicle for the switched +12 (which in my kit was a loose red wire) and either to the battery or another add a circuit to the fuse box for the constant +12 I used the fuse box method on my trailblazer so I didn't have to spend the 100+ for the integration harness
(Prolly not the best way but its the way most people do it)
