ford ranger 4th order box design
noser7
Hey guys i have 3 fi n2 12"s and i have a 91 ford ranger that i want to stuff a 4th order in the trunk. What are basics of a GOOD 4th order? Is it worth the effort to do a 6th?
Im not going to compete but i want something really loud just for my listining pleasure. I will be runing them of a soundstream xxx 6500, future plan is to pick up a second on and strap them on the 3 n2's.
Any feed back is greatly appriciated.
Edit: NVM.
Are you looking to do a blow through?
Builds:
So you DO want a blowthrough? The hole won't be tiny for the port area required for 3 12s. I have a 12X22" port for 4 12s. Those are inside dimensions of my port. The outer dimensions are 15X25" so it's a pretty decent sized hole.
Itll be beter than cutting a hole to stuff a regular ported box in i think.
I just have no idea how to design it
I want 2 cuft per sub on the sealed side. so that would mean that i would need 12 cuft on the ported side wouldnt it, if i wanted a 2:1 ratio?
The lows come from sealed side. I'll say that 2 cubes per sub sealed should have the lows covered. For 3 of those subs, I'd consider between 150-200" of port. That's a rough estimate, nothing precise. I didn't run any numbers and don't like to design bandpass for guys I don't know or can't help in person.
How do you know you want 2 cf on the sealed side? Where did you come up with that number?
I really hate bandpass box ratios. What frequency range are you wanting to play well with this box?
Builds:
  • Who's Online   0 Members, 0 Anonymous, 3112 Guests (See full list)
