StuntBoy Posted October 15, 2015 Report Posted October 15, 2015 So I've been having some issues with my system since I've installed it. Engine noise is coming thru the speakers and gets louder when I accelerate. I've checked everything and seen some YouTube videos,but nothing. Today I found out it's the remote wire going to the amp. Anyone Ever deal with this?
SIDE SHOW Posted October 15, 2015 Report Posted October 15, 2015 How did you find out it was the remote wire? more info on the system (headunit? amps and speakers, info on wiring setup?)
StuntBoy Posted October 15, 2015 Author Report Posted October 15, 2015 Head unit is an pioneer avh 7000 Mid amp is soundstream 300watt 2 channel Bass amp is soundstream Picasso 1500 mono amp I found it it was the remote wire because once I unplugged it the noise stopped
sbg Posted October 15, 2015 Report Posted October 15, 2015 Head unit is an pioneer avh 7000 Mid amp is soundstream 300watt 2 channel Bass amp is soundstream Picasso 1500 mono amp I found it it was the remote wire because once I unplugged it the noise stopped Well didn't the amp turn off when you unpluged the remote? Makeing the sound go away because the amp was not on... 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
StuntBoy Posted October 15, 2015 Author Report Posted October 15, 2015 The system is in a 2001 astro cargo van,I unplugged the factory antenna That goes into the head unit. And it turns off the radio,once I connect it back the radio turns on. Have no idea what's going on here lol
sbg Posted October 15, 2015 Report Posted October 15, 2015 Grounding problem? 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
SIDE SHOW Posted October 15, 2015 Report Posted October 15, 2015 Unplug the rca's from the mid amp and the noise will go away i'm guessing
StuntBoy Posted October 15, 2015 Author Report Posted October 15, 2015 ☝️ the wining noise will still be on the bass amp
