bmxkid4
Hi i need help for a box design for the Soundqubed HDC3 10 inch. Here are the recommended specs for it.
HDC310 - 1.5 cube net with 17 sq inch port area per cube - tune between 36-41 hz
I am going to be putting it in a Subaru BRZ so trunk space is limited to about 13 inches height. I will be running 1200 RMS to it. If you guys could help me out that would be great!
Here is a suggestion, you need to make sure the suggested dims will work for you, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
So the MAX height is 13 but not sure if that would fit so it there a 12 inch height one you could do?
  • Who's Online   1 Member, 0 Anonymous, 390 Guests (See full list)
