ESX QX1222 Box for my Toyota Aygo
nahinder
Its a small difference so you could go ahead and dismiss if that was the case but I don't know how is your port or how you calculated it.
Sub up I imagine, your port length can be shorter due to the end correction for slot ports, also some heavy bracing may be needed for that sub. Will seek to double check those calculations.
I added correction to the port but i need to substract that ? Where do i need to put braces ?
Its gonna be Sub and port up
The has to be 10cm less wider so im losing around 5 liters again
Thnx Joe
I think ive seen this link before but just like this one it just brings me to the homepage of jl ive tried looking for a port explaination on there but looks like its not there anymore.
Yes this is exactly how i calculated the length of the port and added the correction
First I calculated the width and length of the port
Width Port: 7.19 CM
Length Port: 94.7 CM
After that the new length with the correction
7.19/2= 3.959
3.959 + 94.7 = 98.295
Then i calculated the lenght of L1 and L2
And after that i calculated the volume of the port.
having a common wall functionally extends the port length (which lowers tuning) as compared with the same port without a common wall, so you build the slot port short (which increases tuning) to land your desired tuning.
Okay so if i understand correctly when you bend a port the sub acts like there is a longer port and my new calculation would looks like this.
Width of Port: 7.19CM
Length of Port: 94.7CM
Port length corrected: 94.7 - (7.19/2) = 91.105 CM
L1: 29 - 7.19 = 21.81
L2: 91.105 - (2x3.595) - 1.8 - 21.81 = 60.305
Volume would be:
L1: 29 x 33.8 x 8.99 = 8811.998
L2: 60.305 x 8.99 x 33.8 = 18324.39797
8811.998 + 18324.39797 = 27.13639591 Liters
Netto Volume: 56
Port Volume: 27.14
Sub Volume: 3
Maximum Dimensions: (CM)
H: 29
W: 100
D1: 41
D2: 32
Needed Gross volume: 56 + 27.14 + 3 = 86.14L
Available Volume: 80.56L
86.14 - 80.56 = 5.58 L Short
So what are my options now ?
Double ported ? (will this decrease port volume ?)
Or do port outside ?
  • Who's Online   0 Members, 0 Anonymous, 893 Guests (See full list)
