07 Trailblazer 4.2L 4th Order Rebuild. 3 Crossfire 8ks, 6 xsv2 15s, Singer Alts
Heres the final product im more than happy with it
CB6EFBD0-56FE-4E37-B5E0-7A1FFE9A901B_zps
27B86893-737C-45F3-B2FD-7A5BC423A6E1_zps
03438137-D44A-4678-93F9-2CB94883B7F7_zps
2007 4.2L Chevy Trailblazer Crossfire Build
6 Crossfire xs v2 15s
3 Crossfire 8ks
4 Crossfire 6.5 Loudspeakers
2 Crossfire ST-1 Super Tweets
1 Pair of Rockford Fosgate T2 5.25 Components
1 Crossfire C5 800.2
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
6 Runs of 1/0 OFC (Sky High and Welding Wire)
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/
Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/
Scores
MECA - 159.2 @ 37hz
USACI - 161.2 @ 47hz
IASCA - 157.9 @ 47hz
So I had a buddy weld the plates with the metal tabs in my truck so the stripper pole could go in and yes the bottom part was a terrible place to weld to it didn't last long but that's all we could do because the loading wall wasn't in yet
EFDF6B80-FB90-4C80-94C7-F36623F466E8_zps
D3164235-488C-4C7A-A007-7512CA2986C9_zps
23F4586C-0331-48FD-9EA2-C5B8AFB4B227_zps
5CAA1034-A606-467C-BFCD-28B2E1B66D92_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
Out with the old door in with the new
E8DB0F5F-8003-45CF-AB3E-B65BC68F0F4B_zps
E58394BE-9370-4784-A0A2-F7AD253B5BA0_zps
Sanded down all the bottoms of the subs and repainted them with black glossy paint
2870E18E-D228-4E2D-9653-B74147624460_zps
D23585F1-B67E-4451-97D4-CFE1459CAF1D_zps
Started mounting the woofer
AFDB357B-68AA-41A5-BD58-953A27BAC337_zps
126DA07C-E854-404A-AD3C-06C5BE26F10F_zps
4A57442A-D0B1-494D-ACEF-8810A078448C_zps
13C05D97-FD98-41FB-89CA-373648EA54F9_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
Time to start mounting the amps and of course the 8k that I had the longest (the one on top) started acting stupid it has been repaired a couple of times and has been a problem since I got it used months ago. So I left it mounting and only ran 2 8ks strapped at 1.9 ohms. I went ahead and bought a new 8k to replace that one. Also I decided it would be a good idea to only run 2 amps until I get more batts.
9DA72E88-190A-4598-AC2A-47E21591BDF9_zps
29C4A088-FB39-48C9-872A-770D01D1B434_zps
2A0DC04E-59C8-4A8D-8759-5A2698DD7A3F_zps
7F6D28A2-7522-4245-BE4C-EDBD4E95CCEA_zps
49CED1CF-B8B4-4206-B4FE-E83FDED4DC9B_zps
B2C00F90-6278-46FD-9C41-284ED133816C_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
Got the loading wall put in
4AC714CA-923C-4B69-B0F1-CA011662018C_zps
DF4C61D2-1C47-49F8-B2EC-93D1FBF3F7ED_zps
Hooked it up to the Datz and found the impedance slope which landed us with a 10.75 wide by 8.5 deep port. What do you know with 2 amps this was probably spot on for the port currently yes it does seem small but worked perfect.
5858CCAD-E1DD-4B77-B524-854BE4228FB8_zps
098E54FB-04F1-4AD6-9626-D5239DE0BA4B_zps
We moved the base of the stripper pole to the box and instantly better
16ED520A-441D-43DD-A144-D6374F9C8966_zps
Then this happened while I'm in line to meter usaci. Damn Selina Gomez. Fuck it tape it up and keep playing lol
0F55A490-E461-45AE-B759-84E86EB2E732_zps
276A53F0-9FC2-44EC-B6A0-2CB3EB374B22_zps
D7A0D1AC-B8CF-4753-8839-A0F2B6E0FDA1_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
With 2 amps at 1 ohm per I was getting 9800 rms at the show I did a 155.4 sealed at 38hz and a 157.9 in the kick nothing special.
We made a stool for the drivers side during demos. I call my stool The Stool Softener
A277819B-EDA1-4CA3-A01F-8EB9AC499228_zps
So I decided to meter after the show and my numbers keep going up
157.3 at 36hz at the Headrest
151 at 20hz at the Headrest
154.7 at 24hz at the Headrest
158.8 at 36hz in the kick
E02CEDE7-1F23-4681-B9BD-2C9E7F6A883D_zps
1ABCF092-DC6A-4664-9488-06C697A1C024_zps
A56FC59E-1C5C-4480-85E2-29263A4BBF80_zps
17DD5F0F-D650-47C5-B4D9-2900F20E6181_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
I got a my buddy CleanSierras 6 C&D Batts for a stupid low price so I had to buy some aluminum to make buss bars so why not 2 inches wid eby 1/2 thick lol. Started ripping the back out to put all the batts in and let me tell you what a tight fit
00E14EF0-11B0-4D10-B8CE-16C21C944045_zps
0F2A7049-6953-4A1E-92D2-31211E909695_zps
A8B5C0D4-5CB3-41D7-AB3F-0FE62884E819_zps
A8A1B007-C61E-402F-A9F4-EC91864075D2_zps
4FAA1D19-FE6C-43E8-9BC5-E1ABCD2907E9_zps
5D4D54BD-0697-46A4-86F8-9BF4377271D9_zps
3365178C-B7D3-49BA-8D11-22E0A1A7ABCB_zps
D65E7C33-AF1D-4AEF-B7A8-9F061B595F01_zps
BEC086FC-CF25-4B4A-ACBB-FEF8B861B8E4_zps
71A3D561-28BE-4A7B-9D49-EB6498017EC6_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
With all the batts in I'm sitting really low now I will be looking into beefier springs to help it
6DA09766-457F-44C1-9306-C6DF6DB90285_zps
C1F840A3-7227-4A71-97AF-338473008E21_zps
9F2C11E3-DF44-455D-955F-9D14AA554347_zps
Currently on a burp I'm getting a little over 8200 rms per amp rising to 1.5 ohms from .5. Amps are gain matched at 96.5 volts I still need to put my audio control matrix in to see if I gain anything from it but I can tell you my numbers are still going up.
91C341E4-7DDA-4A9B-BAA2-D540C2FC97F9_zps
We did make the port 12 inches wide by 10 inches deep to allow it to breathe more. So here is the numbers so far
159.2 at 37hz at the Headrest
158.6 at 47hz at the Headrest
157.71 at 30hz at the Headrest
154.9 at 23hz at the Headrest
161.2 at 47hz in the kick (Official Usaci) Did a 161.6 in testing
157.72 at 47hz sealed on the dash. I did a 157.9 but forgot to take a pic I'm sure in in the 158s now
91A9658D-5099-43DA-B387-D4A9B9320289_zps
E2EED5CE-0ED1-4513-A8A3-036CB10E9BBD_zps
6F85A3F1-DB06-4168-969F-C184FDD53E61_zps
254D9F1B-2E96-461B-9AE6-92F7A075D527_zps
AF9445A4-AA9C-4D8D-88BC-6EA1DC447D92_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
At this weekends Usaci show in Tucson I surprised everyone and took home 4 1sts and loudest of the day with a 161.2
9604B23D-5F79-4868-82C2-E2E921A7CDDC_zps
A9D5D90F-BB4E-4628-8345-C54ABBC72197_zps
3 Crossfire 8ks
1 Crossfire 400.2's
7 XS Power xp3000s
​6 C&D Batteries
3 Singer Alts
SMD VM-1
SMD OM-1
Pioneer AVH-p4800BS
Build Log
Scores
MECA - 159.2 @ 37hz
