ll_wwcnd_ll Posted November 1, 2015 Report Posted November 1, 2015 Hey Guys i havent been on here in a while but im finally back around to posting again. Im also rebuilding which is the point of this build log. Heres what the build contains. 2 Crossfire 8ks (Strapped at 1ohm) 4 Crossfire xsv2 15s 4 Crossfire M6 Loudspeakers 1 Crossfire BMF 400.2 1 Crossfire C5 800.4 4 Crossfire XS-ST1s 1 Set of Fosgate T2 5 1/4 Components 1 Set of Fosgate T2 Tweets 2 Singer 320amp 6 Phase alts 1 Ohio Gen 220 amp alt in stock location soon to be the first Singer 370 6 Phase 6 runs of 1/0 OFC 7 XS Power xp3000s (Maybe switching to Reikken)SMD VM-1 and OM-1 Pioneer 9600BHS So heres the specs on the 4th Order. Everything was designed by brent379 one of my buddys Starting off big on everything to make it easier for tuning once its playing. Sealed Side will be about 7.5 cubes and the ported will be about 28 to 29 cubes. Yeah thats a huge ported area but like i side that will more than likely be coming down to be about a 3:1 ratio. Port will be tuned to around 47 to 48hz and will start off at 480 sq inches. On to the pics Heres what it will it will look like yes somethings wont be exactly like the sketchup but you get the idea First thing that had to be done was to build a good platform. From there had to make the platform level with the back cargo area Next time to move on to the floor. Next was the fun part getting the roof to be as solid as possible so that means 8 tubes of PL 8x spread on 1/2 MDF and secured to the roof 2007 4.2L Chevy Trailblazer Crossfire Build6 Crossfire xs v2 15s3 Crossfire 8ks4 Crossfire 6.5 Loudspeakers 2 Crossfire ST-1 Super Tweets 1 Pair of Rockford Fosgate T2 5.25 Components 1 Crossfire C5 800.2 1 Crossfire 400.2's7 XS Power xp3000s 6 C&D Batteries3 Singer Alts 6 Runs of 1/0 OFC (Sky High and Welding Wire)SMD VM-1SMD OM-1Pioneer AVH-p4800BSBuild Log4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/ Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/ScoresMECA - 159.2 @ 37hzUSACI - 161.2 @ 47hzIASCA - 157.9 @ 47hz
ll_wwcnd_ll Posted November 1, 2015 Author Report Posted November 1, 2015 Let that sit for a day and let the PL get as cured as possible then thats when we started kreg jigging 2x4s that were cut specifically to contour to the roof. Time to finally see how strong the roof is. Sorry i will upload the vid on youtube soon http://i1272.photobucket.com/albums/y381/phillyflapjak/Crossfire%20Build/Crossfire%204th/th_019A572C-F440-485F-930C-6F352D93DE1E_zpscrwprnkm.mp4 Since the roof is done we ran into a little issue with the sides because the way my roof is so we made a piece that would connect to the roof and go flush with the side of my truck. Every side has been Kreg Jigged as well as the inner layers all glued with Tight Bond 3 glue and a generous bead of PL8x for extra support 1 more layer to put up 1st side is finally complete 2007 4.2L Chevy Trailblazer Crossfire Build6 Crossfire xs v2 15s3 Crossfire 8ks4 Crossfire 6.5 Loudspeakers 2 Crossfire ST-1 Super Tweets 1 Pair of Rockford Fosgate T2 5.25 Components 1 Crossfire C5 800.2 1 Crossfire 400.2's7 XS Power xp3000s 6 C&D Batteries3 Singer Alts 6 Runs of 1/0 OFC (Sky High and Welding Wire)SMD VM-1SMD OM-1Pioneer AVH-p4800BSBuild Log4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/ Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/ScoresMECA - 159.2 @ 37hzUSACI - 161.2 @ 47hzIASCA - 157.9 @ 47hz
ll_wwcnd_ll Posted November 1, 2015 Author Report Posted November 1, 2015 The other side is complete so here is the shell as it sits. Everything will be 3 inches (4 layers of 3/4 MDF) Decided it was a good time to start spray foaming only went thru like 8 cans not too bad Took some work and some bad decisions but finally got the first baffle done lol Finally all 4 baffles are done next thing on the list is to router them Testing the first sub after the first hole was cut 2007 4.2L Chevy Trailblazer Crossfire Build6 Crossfire xs v2 15s3 Crossfire 8ks4 Crossfire 6.5 Loudspeakers 2 Crossfire ST-1 Super Tweets 1 Pair of Rockford Fosgate T2 5.25 Components 1 Crossfire C5 800.2 1 Crossfire 400.2's7 XS Power xp3000s 6 C&D Batteries3 Singer Alts 6 Runs of 1/0 OFC (Sky High and Welding Wire)SMD VM-1SMD OM-1Pioneer AVH-p4800BSBuild Log4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/ Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/ScoresMECA - 159.2 @ 37hzUSACI - 161.2 @ 47hzIASCA - 157.9 @ 47hz
ll_wwcnd_ll Posted November 2, 2015 Author Report Posted November 2, 2015 Time to start putting the baffles in. Each baffle was kreg jigged and the inner layers were glued screwed kreg jigged and PLed. 2007 4.2L Chevy Trailblazer Crossfire Build6 Crossfire xs v2 15s3 Crossfire 8ks4 Crossfire 6.5 Loudspeakers 2 Crossfire ST-1 Super Tweets 1 Pair of Rockford Fosgate T2 5.25 Components 1 Crossfire C5 800.2 1 Crossfire 400.2's7 XS Power xp3000s 6 C&D Batteries3 Singer Alts 6 Runs of 1/0 OFC (Sky High and Welding Wire)SMD VM-1SMD OM-1Pioneer AVH-p4800BSBuild Log4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/ Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/ScoresMECA - 159.2 @ 37hzUSACI - 161.2 @ 47hzIASCA - 157.9 @ 47hz
Karkov Posted November 2, 2015 Report Posted November 2, 2015 holy shit tuned in as well 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
Mr DeeBeez Posted November 2, 2015 Report Posted November 2, 2015 Tuned in for sure! Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
Mr DeeBeez Posted November 2, 2015 Report Posted November 2, 2015 Double post Fi Team 18's (4) Crossfire 16k Crossfire 400.4 & 800.4 Pioneer AVH-X491bhs 140ah cmax CES 320's (2)
Smoove Posted November 2, 2015 Report Posted November 2, 2015 Nice, rebuild gets a new thread. 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/
ll_wwcnd_ll Posted November 2, 2015 Author Report Posted November 2, 2015 Had a buddy of mine weld a brace for the sealed side i say it turned out really nice Thats about it for right now i still have to do the loading wall the back wall the back of the truck as well as the front and center console but that shouldnt take too long 2007 4.2L Chevy Trailblazer Crossfire Build6 Crossfire xs v2 15s3 Crossfire 8ks4 Crossfire 6.5 Loudspeakers 2 Crossfire ST-1 Super Tweets 1 Pair of Rockford Fosgate T2 5.25 Components 1 Crossfire C5 800.2 1 Crossfire 400.2's7 XS Power xp3000s 6 C&D Batteries3 Singer Alts 6 Runs of 1/0 OFC (Sky High and Welding Wire)SMD VM-1SMD OM-1Pioneer AVH-p4800BSBuild Log4th Order BL - http://www.stevemeadedesigns.com/board/topic/189896-4th-order-crossfire-trailblazer-buildlog/ Flat Wall BL - http://www.stevemeadedesigns.com/board/topic/198087-2007-42l-chevy-trailblazer-flat-wall-rebuild-build-log-4-crossfire-xsv2-15s-2-crossfire-8ks-xs-power-batts-singer-alts/ScoresMECA - 159.2 @ 37hzUSACI - 161.2 @ 47hzIASCA - 157.9 @ 47hz
