Nick4029 Posted November 5, 2015 Report Posted November 5, 2015 I have a zv4 12 rev 2 on a hifonics brx2400 in a 2.75ft3 box tuned to 32hertz. Also have a 160 amp alternator. When I play lower notes anywhere from like 45 hertz and down my voltage is good and doesn't drop below 13.8. My voltage is regularly like 13.9. I'm lucky to get to 14 because of my voltage regulator my car has. But when i play songs with notes that are 45 hertz and up (like the hills by the weekend) my voltage drops anywhere from 13.4-12.2 depending on the song. It's seems the higher the hertz the lower my voltage drops. And the lower the note the higher my voltage is. Can anyone explain to me why this happens Thanks 2011 Chrysler 200s Sundown zv4 12 rev2 2.75ft3 box tuned 32hertz Hifonics brx 2400 Sky High 1/0 ofc power and ground wire Sky High 8 gauge ofc speaker wire Focal auditor 5 1/4 front component speakers Focal integration 6x9 rear deck speakers Stock 160amp alt
Massivespl Posted November 5, 2015 Report Posted November 5, 2015 Ur drawing more power on the high freq.. c-pillar flat wall 157.11db on music 2 crossfire 8k 4 NSV3 18s 4 crescendo 10s 4 Rockford pro 6.5s Quad excessive amperage 350alts 4 juicebox 3100s
everybodyknowme Posted November 6, 2015 Report Posted November 6, 2015 My brx2400 did that too but I don't drop low anymore since upgrading alt to a 240
Nick4029 Posted November 6, 2015 Author Report Posted November 6, 2015 My brx2400 did that too but I don't drop low anymore since upgrading alt to a 240 That's good to know. I'm upgrading to a singer 250a alt soon so hopefully it will go away 2011 Chrysler 200s Sundown zv4 12 rev2 2.75ft3 box tuned 32hertz Hifonics brx 2400 Sky High 1/0 ofc power and ground wire Sky High 8 gauge ofc speaker wire Focal auditor 5 1/4 front component speakers Focal integration 6x9 rear deck speakers Stock 160amp alt
Ahmed Johnson Posted November 6, 2015 Report Posted November 6, 2015 Do you have the bass boost up? Those amps have it set at 45hz so turning it up will cause it to pull more power on those higher frequncies
Nick4029 Posted November 6, 2015 Author Report Posted November 6, 2015 Do you have the bass boost up? Those amps have it set at 45hz so turning it up will cause it to pull more power on those higher frequncies I think I might I'll have to check when I go on break. I never even thought of that 2011 Chrysler 200s Sundown zv4 12 rev2 2.75ft3 box tuned 32hertz Hifonics brx 2400 Sky High 1/0 ofc power and ground wire Sky High 8 gauge ofc speaker wire Focal auditor 5 1/4 front component speakers Focal integration 6x9 rear deck speakers Stock 160amp alt
khinds94 Posted November 6, 2015 Report Posted November 6, 2015 It's the impendance curve of your box. With little reserve and alt it's easier to see. Mine system does the same 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
