Has anybody ever used this type of liner? I'm planning a entertainment setup on my garage and wanted to spray the mdf with it so it doesn't expand when I hose the floor down. If you've used it? Does it coat well enough to protect against water? Im concerned that water might get through the coat of liner and make the wood expand.
If you've used it, what's your opinion?
Team Bass-Hz
My advise would be use a water resistant base coat under a thick coat of this stuff
(Never used this or any sprayon bedliner)
I ended up buying a similar product different brand. The liner says its waterproof so I guess we'll see how it holds up. Thanks for your input
Team Bass-Hz
I used ROCKET LINER in 75% of my cabin. On the wall, side panels, roof, door panels.
I like it.... and will use it again.
I ended up going with raptor liner
Team Bass-Hz
Thats what Mead uses... it the same shit. Itll do the job just fine.
Me and the Fi's thank you for the help.
Team Bass-Hz
