sebringR/T Posted November 11, 2015 Report Posted November 11, 2015 So some of you may have seen my build log, some may not, but I'm driving a 2010 Ford Taurus Limited with Sync and the 12 speaker stock amplified system. I have currently bypassed the stock headunit and I'm running a Pioneer 80PRS that I have located underneath the drivers seat where I can still reach it to control the volume and make setting changes if needed. Today I purchased a RF 3sixty.3 to replace the 80PRS because I hate that it is sitting underneath my feet and its not fully secured so when I'm taking corners its sliding from one side to the other underneath the seat. I know that the 3sixty requires high level outputs from the stock system. I do have some wiring diagrams for the audio system but nothing really specifies if it is high level or low level. Is there any way to find this out with a multimeter? Anyone have any input? I was hoping to find some information on Meade's F150 build but it doesn't seem that he has gotten that far into the truck build. Btw...build log is also located in my signature if you want to take a look. Team Droppin' Hz Tuxedo Black Metallic 2010 Ford Taurus Limited Build Log "Financial Mistake"
wizart383 Posted November 11, 2015 Report Posted November 11, 2015 Low level are rca's High level are the speaker outputs from the the radio
sebringR/T Posted November 11, 2015 Author Report Posted November 11, 2015 Low level are rca's High level are the speaker outputs from the the radio Can I pull them from where they go into the stock amplifier? Team Droppin' Hz Tuxedo Black Metallic 2010 Ford Taurus Limited Build Log "Financial Mistake"
audiolamb6 Posted November 11, 2015 Report Posted November 11, 2015 from what ive heard most factory systems are high level. i did google and from what i found it looks like yours is to
