? On setting gain lower than amp can do
fordpride
My dmm will freeze frame highest voltage. Can I take that then do the math on it to find out what the amp is doing ?
I mean yes you could. But your amp does not put out a cotinuos power. It will vary greatly. Your ohm load varies greatly also. I haven't looked at the specs of your subs but I'm assuming 250 is rms and not max. You are either clipping or its newness/dirty Ness of subs. You are not overpowering them. What kind of music are you playing? I believe dirty music can have I'll effects on your subs.
Still learning but have started gathering.
Also is the smell appearing immediately or is it after some time at higher volumes?
Sub specs
CEA-2031 Compliant: CEA-2031 Guidelines
Nominal Impedance: Dual 2-Ohm
Power Handling (Watts RMS): 250 Watts RMS
500 Watts Max
Voice Coil Diameter: 2" (51mm)
Magnet Weight (oz): 47.7 oz. (1.35 kg)
Speaker Connector: Dual 12 AWG compression
Fs (Hz): 34.6
Re (Ohms): 3.80
Le (mH): 3.9
Qms: 8.29
Qes: 0.62
Qts: 0.58
Vas (Liters): 66.4
Sd (cm2): 539.1
SPL (dB @ 1w/1m): 88.7
Xmax (mm): 6.5
Woofer Displacement (in): 0.046 cu.ft. (1.3 Liters)
Cutout Diameter (in): 11.25 in. (285 mm)
Mounting Depth (in): 5.067 in. (128.7 mm)
Shipping Weight: 9.9 Lbs. (4.49 kg)
Support
Only two song have been play.
E40 gargoyle serenade
Sean p be like me
Smell come a couple mins after playing.
Volume at 38. HU goes to 63
