Adding Agm Battery To Stock Battery
They obviously are going to be two completely different batterys. Will this work just like wiring up two batterys of the same kind? Or is there something I need to make this work.
Its best to use 2 identical batteries (same brand, model, age, etc) but it will still work fine as long as both batteries are in good condition. You dont want to do it if your stock battery is old and weak to begin with.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
Its in good condition, havnt had it to long. So I would just wire them together like normal and shouldnt have a problem?
Only doing it because the Powermasters are to tall and wont let my hood close unless I modify the battery mount some how. I figured it'd be easier to just leave it and add to it if possible. Its some what of a big stock battery I guess....
you'll be fine...just run the positives together, and the same with the grounds...and fuse the positive run at both ends...
i likes me some audio stuff...
  • Who's Online   0 Members, 0 Anonymous, 3616 Guests (See full list)
