Extended Cab Silverado Install
AGuyWithAJeep
Nice looking step up. My son wants something like this in his 94 GMC ext cab.
I have 2 hds208s under my seat 1 cube net per chamber. 2 inch ports. No port noise. IMG_403487312241826.jpeg
Not trying to pick on you, but that's not a ported box. What you have is a leaky, oversized sealed box. You are going to have port compression before you even put 50 watts to that box. Port noise isn't the only symptom of an undersized port, and it isn't always audible. You can't hear the output your are losing due to an undersized port.
Builds:
Alright so before I start building this, does anyone have a better idea as to what I should use to keep the fiberglass from getting on the carpet when I mold the floor of it? I want to find something that can take the shape of the floor but won't let the fiberglass through. My original plan was aluminum foil and just layer it up across the floor but I'm not 100% sure that's the best idea
I'm not a fiberglass guy, but usually what I see people use is a layer of masking tape over everything and then they coat it in non-stick spray.
Builds:
  • 4 weeks later...
Alright sorry it's been so long since I've updated. I graduated from college, holidays came around. Bs bs bs, anyway the list of things I have has changed. I've got the 2 AB VFL 8s still, just now i have an American Bass PH4000md instead of the Rockford amp. The weather around here just started getting cold and I'm not sure when I will be able to start glassing the box together, although the front and sides are already made out of 3/4 mdf. The amp will mount right in the center hump part of the box recessed back a little to give it a nice clean look (and there is no where else in the damn truck to put it). The 2 3" aero ports I have will be mounted one on each side facing the doors basically. Also I found this stuff called "Carpet Sheild" which is a self adhesive 24 foot by 2 foot roll of a plastic like protectant for keeping the carpet in your house safe while painting and what not. I figured I may as well try it and see how it turns out while glassing the box. Still haven't got the headunit wired in yet either but I did get my dual battery and big 3 done under the hood :) I'll try to get as many pics of it as I can when I finally get some nice weather or find a garage that's heated. Hopefully soon because I'm starting to grow impatient ?
  • Who's Online   0 Members, 0 Anonymous, 3222 Guests (See full list)
