Finally built another computer
Since the last computer i built had an 8800gt circa 2007 i decided it was time for a new one! Some things i got for budget and will upgrade later but its a pretty solid unit IMO
Specs:
Intel core I7 4790K OC to 4.6ghz
32 Gigs DDR3 PC3-19200 2400MHz TridentX Series CL10
EVGA GeForce GTX 960 4GB SSC GAMING ACX 2.0+
128 GIG SSD
1TB 7200 HHD
Thermaltake 850W PSU
I have the CPU clocked at 4.6ghz
the GPU core is clocked +40mhz and Memory +400mhz (i need to learn more on tweaking the GPU any advice would be AWESOME)
I have not OC the RAM yet still getting to that point.
Everything so far runs smooth as butter, the CPU will clock all the way up to 4.8 crashes at 4.9 but runs hot with current cooling 4.7 was stable after a 15 minute full load but sat at 74C so i backed down to 4.6 and running crysis 3 at very high on 1080 the CPU hasnt gone past 50C and GPU past 61C
Still getting used to the BIOS on the new boards and i know i can still do alot more. Any advice on what you think i could OC the GPU to or the Memory ill take anything i can get.
Hope you enjoy! will get a 3Dmark score up soon!
update ... crashed .... after 30 minutes .... finally capped out and said i quit so i backed it down to 4.6 just for longevity reasons. could up the voltage but just dont want the extra heat and stress on the CPU
still love this computer!
I think oneof my problems is im using the coolermaster thermal paste that came with the cooler ... need to get some arctic silver
also if you can use another fan on the heatsink... I used a low profile noctua setup on the heatsink itself, 2 x 120mm so it created a stronger tunnel out the back...
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
