Hotdog Posted December 13, 2015 Report Share Posted December 13, 2015 Did my first calibration today with the DD-1. Pretty simple to follow but had interesting results. Tested a Pioneer Head unit max volume is 62 did not clip until I hit 60. Pretty clean Went into a Kicker crossover from radio so I tested and adjusted the output of the kicker crossover. Out of Crossover to the mids / highs amp which was a pioneer. Hooked DD-1 to the speaker wire output and turn gain all the way down. Start track two and adjust the gain and I go all the way to max gain with no clipping. That cant be common can it? Max gain and no clip? (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
reedal Posted December 13, 2015 Report Share Posted December 13, 2015 i believe the issue with that in another recent DD-1 thread was that the crossover points were filtering out the signal, to the point that the amplifier being set was clean all the way to max when using the DD-1. so make sure allllllllllll filters and crossovers are off or set to full pass. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
