bmwking Posted December 17, 2015 Report Posted December 17, 2015 I found an Alpine cde-143BT, harness, antenna adapter and single din dash kit on amazon for $139 total. I was going to link it here but remembered you need voice control. I'm pretty sure youre fucked at your budget if you absolutely need voice control.
Deeznutz Posted December 17, 2015 Report Posted December 17, 2015 You're entitled to get whatever you want. Double din or single din. Just make a purchase based on what you need, not so much what you budget will allow. Always start at the head unit. A good one. Once that is in, it will make your stock speakers sound better. Go to a junkyard (like LKQ) with a phillips head screw driver and start ripping about door panels, especially in the import section. You're likely to find some Infinity 6.5 coaxials. I personally found 3 pairs at the Largo LKQ for $9 a pair. (I flipped them on Ebay for $38/a pair) You can also find Infinity 6x9's for now as well. Infinity is a better upgrade over stock, at least for now. For Under $10 and your time which might be hit or miss the first or second visit it's worth it to try to find some. Install them, and work, work, work for a nice set of Focals. Just do not say, you want to limit your headunit cost to get a good set of components because that's prioritizing things backwards. -Frank
