jfoodstamp Posted December 16, 2015 Author Report Posted December 16, 2015 Is there any negatives to crossing over my Image Dynamics Ultra horns at 950hz? I have ran these at 1500hz and up with great success but Inwanted to see if crossing them over would be advantageous?
MADVIBES Posted December 17, 2015 Report Posted December 17, 2015 950 seems low even if you run a 3rd order filter seems like a good way to get distortion at a really low volume. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
jfoodstamp Posted December 17, 2015 Author Report Posted December 17, 2015 I will be using my Audiocontrol 6xs with a 24db slope
jcarter1885 Posted December 17, 2015 Report Posted December 17, 2015 Depends on body style, if I remember correctly you don't want to cross the mini-bodies below 1200hz and I believe the large-bodies can crossed as low as 800hz. Don't quote me on this, check out the HLCD section on the DIYMA forum as it can be answered there. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
jcarter1885 Posted December 17, 2015 Report Posted December 17, 2015 Definitely wouldn't want to cross the mini-bodies that low. Like stated above, go to the DIYMA forum and see what is a safe crossover range for your application. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Carnines Posted December 17, 2015 Report Posted December 17, 2015 Email eric @ [email protected] since he designed the horns. Here's what he says for his current models, which I am not sure if they are the same as the ID models(pretty sure they aren't). 1200Hz xover MH both models800 Hz xover Full Size for both 600 to 20Khz + for both with full size800 to 20Khz + for both with MH
