Ground continuity question
So I just finished wiring up 4 batteries by soldering the lugs on and tested the continuity of the negatives and it was jumping around slowly from .4-1.9. Is this something to be worried about??
I know .0 is perfect and ideal but is 1.9 something to worry about? I don't wanna start blowing up my amp.
Edit: Just tested again with actually touching the wire instead of holding the probes onto the bolts and it seems to be staying at .0. I think I'm good!
If anyone could explain to me thought what a bad continuity would be that'd be great.
Bass head in training. Trying to learn everything I can.
2014 Dodge Dart GT
Synergy Audio WFO 15.1 V2 (Prototype)
Sundown X12
without any load you should be close to a 0 vdc drop.... I dont know what test you are doing but did you make full ground runs or are you going frame?
Just from my first battery to my last battery (fourth). Testing in ohms on my DMM. Batteries are out of the car right now just wanted to test continuity with my soldered connections.
2014 Dodge Dart GT
Sundown X12
check your grounding. shouldn't have jumps of such with clean connections.
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
what size cable.... and how many feet
1/0 Gauge, they are all 10" long and there is 6 of them so 5' worth of cable. When I touched the probes into the actual wire it was holding steady at 0. It was jumping around when I just was holding the probe down with my thumbs on both ends. It's good now.
2014 Dodge Dart GT
Sundown X12
when testing continuity do not actually touch the items you are testing/lead ends with your fingers as it will muck up the readings. just holding the two leads from a meter with your fingers will show continuity through your skin/body.
^^^ That
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
^^^ That
This makes perfect sense and would explain why when I probed the actual wire in between the jacket and lug before I added heat shrink it read 0 consistently! Thanks for your help!
2014 Dodge Dart GT
Sundown X12
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
