The Team v2 (which is neo). but no confirmation on release date.
The SD-3 8inch should be sometime in 2016.
There is also a new E series v3 shall be releasing early in Februaryish 2016 with a new basket, larger leads, and a bumped back plate to prevent bottoming out the coil.
The ZV5 should be coming out around June 2016 (but possibly sooner).
Yep this is all correct information.
Not sure how many folks noticed we did release our "NEO-SPL" driver in the 4Q of 2015 :
https://www.facebook.com/media/set/?set=a.897828580272614.1073741877.114478905274256&type=3
The NEO-SPL is currently on v.1 & will be for the first ~100 or so units while I work on the v.2 version.
For the time being I am not changing the Z v.5 power rating from 2000-watts... although; it runs the same coil as the NS v.3 now.
The NS v.4 is in the works. I have the final production run of NS v.3 motors coming in shortly... this will make the last of them! In total the NS v.3 will have 3x the number of units on the market as any prior NS woofer so it was a great success... I am going for the redesign as the Z v.5 will push in closer to NS v.3 territory.
The TEAM Neo is being made first & foremost to reduce weight. Since the goal is simply to have the *same* flux (and hence BL) as the current TEAM model we don't need to use crazy amounts of Neo... therefore the goal is to keep pricing very similar to the current TEAM woofer but at ~1/2 the weight.
I have also worked in a few cooling upgrades & distortion reduction upgrades.
The E v.3 series 10/12/15 models also step up to a 2.5" coil compared to a 2" coil from prior generations -- they are BEASTS for the cost.
Another item... the LCS-12 will be surfacing in 2016... this will be our $79 retail woofer.
https://www.facebook.com/media/set/?set=a.897822013606604.1073741876.114478905274256&type=3
There will be more... I suggest tuning in to our Facebook page =)
So that neo is to be expected to be around 60 lbs or so? And keep the power the same, keep the motor force just about the same, expect the same woofer so to say, but able to get one of front baffles? Sounds cool man
2016 is gonna be awesome
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
  • Who's Online   0 Members, 0 Anonymous, 1064 Guests (See full list)
