Chris Braun Posted January 21, 2016 Report Posted January 21, 2016 Hey guys, More curious than anything. Say you have sub out 1 and 2 on your receiver, meant for a dual subwoofer setup. Is it going to hurt hooking up a single sub to both of those outputs meaning the left and right input on the sub for a better signal? In anyway is the 5.2 setup stereo bass? Both the sub 1 and 2 outputs should be exactly the same no? I know, use a Y splitter, but like I said, just curious.
hdorre Posted January 21, 2016 Report Posted January 21, 2016 the sub output signal is generally mono anyway On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
ChuckStakes Posted January 21, 2016 Report Posted January 21, 2016 I believe the two channels are there so you don't have to have a y-splitter . If one sub I would run channel 1. If two than channel 1 & 2. If there were separate channels with different playback than you wouldn't want to run both to one mono sub. I assume 5.2 would be running different frequencies and volumes through two different subs (dual sub setup)Does that make sense? Also I figure two more better, a more enveloping sound, if you have the room
CleanSierra Posted January 21, 2016 Report Posted January 21, 2016 Bass is non directional. Hooking up one channel is just fine. Im not the one you want to try to troll. Just a fyi for you.
bmwking Posted January 21, 2016 Report Posted January 21, 2016 do each of the outputs actually send signal at the same time? I had a 7.2 receiver with 2 sub outs and #2 would only work if i was wiring to include a 2.1 setup in addition to the 5.1. I tried to do a 5.2 setup with 2 separate powered subs and only one gave output. both were in fine working order.
Chris Braun Posted January 22, 2016 Author Report Posted January 22, 2016 Hmm, ya that sounds like the receiver itself or some sort of setting. I've never heard of a setting like that though as mine just has subwoofer on or off, which I'm guessing turns both outputs on or off. More or less confirmed what I was thinking though. Mono signal, just wondering if they are separate signals or just 1 signal split on the board, probably the latter.
