2 sundown sa 12s box help ...joex
punchy
So here is a second suggestion port to the side, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Ok sweet im going to be buying wood in about an hour and start building it and ill post pics and let you no how it works out thanks bro hopefully nothing happens to my car this time hahaha lol and I well be putting 45s in this
Ok check your measurements well, if the box baffle takes all the rectangle then you need to do a seal off, if the box doesn't cover the rectangle by a good margin then you can fire back if you want.
Duck I made a fake box to see if if it would fit and it wont work with it being 29 inches I can only get away with 17 or 18 inches deep
See if you can fit this, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:
  • Who's Online   1 Member, 0 Anonymous, 518 Guests (See full list)
