Multiple power runs
Is there any downsides to running multiple small power runs (ex. 2 4ga runs)
Reason I ask is I got 2 clearance (75% off remodel sale) ofc install kits and for the wattage I'll be running 2 runs would be just over kill enough that I would feel safe doing it untile I upgrade wattage
Each kit is 560 watts rms rated iirc I'm only gona run 900 total so in theory I would have ~220 of extra wiggle room
(Tl;Dr) is there any downside to running two small runs instead of one big run other than cost
I already know you can I'm just asking for downsides (if there is any)
I dont have the numbers but 2 runs of 1/0 flows more current than 1 run of 2/0... so 2 runs of 4.... 4awg can flow more amps than people really think... not for a 3,000 rms system but I stick with a single run of 4 SHCA CCA and have no problems with voltage drop on stock electrical pushing around 1,500 rms.... if the wire kits you bought are AWG real sized then you should be golden for quite some upgrades in the future... but if its low grade 4 gauge then it might be closer to 6 gauge.... what brand is this wire?...... while ago I bought a cheap kit for a person at work and said do not buy it but he instised and I measured the wire with a pair of calipers and showed him it was not even close to 4awg but he still did not care.... it was his $15 not mine
It's a scoche kit the 1200 watt kit (in the fine print it says 560rms) so I would geuss middle of the road quality but idk
In installing it now but it got to cold (~20F here) so I'm taking a break
http://m.ebay.com/itm/141761668699?_trksid=p2141725.m3641.l6368 not where I bought it but its the same one
2 runs of four is roughly 2 gauge worth of wire, it would take 4 runs of 4 gauge to have the same capacitance as a run of 1/0, that being said you are for sure safe so long as your wire doesnt get warm you are golden.
DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ
LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ
MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY.
156.9@26hz  158.0@30hz
Correction its 6ga
Aside from that from what I under stand the only down side is cost and its not as good as 1/0 (not really a big deal to me as I'm not gona upgrade my amps without upgrading wire)
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
