Port dimensions
afrakes
On the calculators, you need to use one that is compatible with slot ports (due to the end correction for slot ports), in addition to that there are many variants of the tuning equation so it's normal to get slightly different results when comparing calculators.
Awesome. Thank you. So looks like by that plot I will maximize my airflow right around 28-30 hz, which is what I'm shooting for
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
I'm assuming the higher line in the graph is 70 in^2, correct?
Subs/Amps: TBD
I know this thread is over but what the Xmax of your woofer ? Did not think to ask you earlier.
If it's not hart stopping it not real POWER
d5a12bcc-c31a-4c2d-90bd-394ef746eb7a_zps0ea163ed-8f00-4686-8c3d-77bccbd0ea03_zps
30mm (one way)
Subs/Amps: TBD
It's the lower one, larger area lower airspeed, in any case both are well below any limits.
Ok, you have to excuse me because this is my first time seeing a graph like this. What exactly are you looking for/what is considered the "safe" range?
I assume too much airspeed and the box will choke/whistle? And too little airspeed it would lose output?
Subs/Amps: TBD
Like 18-20 m/s is usually adequate, less than that will not gain you much output rather than have you loose it but the larger port means a larger heavier box.
There really isn't such a thing as "too little airspeed". High output doesn't come from higher port velocity. If your port velocity is really low, it just means your port is bigger than it needs to be, which wastes space.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
