2 subs, 2 amps. wiring question
I have a question regarding the wiring for a dual amp, dual sub configuration.
I have two Dual 1 Ohm subs, and two amps.
If I strap the amps, the load needs to be a minimum of 2 Ohms.. is this possible with my subwoofer set up?
Is there another way around this? Such as wiring each sub separately but still daisy chain the amps... i dont know... kind of a noob when it comes to the electrical stuff.. Any help would be appreciated. i have searched around, but have not quite found anything useful..
F O.
All coils in parallel will give you .25 ohm. All coils in series will give you 4 ohms. Dual coils in series and subs in parallel would be 1 ohm. Maybe run just one amp or get two more subs. Two ohm coils would have worked better for what you are trying to do.
Pioneer 80PRS
What amps do you have?
Pioneer 80PRS
Yes, my original setup was a single amp. Got a great deal on two recon 1.6's..
Anyhow, so instead of truly strapping these, you're saying wire independently.. Then could I just use the rca out to the other amps rca in? Is that what you are referring to when gain matching? Or are you suggesting I manually set each amps gains separately?!
F O.
daisychaining and strapping are not the same thing.... using the rca passthroughs to feed signal to more amps is called daisychaining.... bridging 2 amps together like they were a single 2 channel amp is strapping..... daisychaining is just so you can save money on rca cables and have a cleaner setup other wise you would need Y splitters everywhere
  • Who's Online   2 Members, 0 Anonymous, 1622 Guests (See full list)
