2 subs, 2 amps. wiring question
Sometimes the input signal link that is used to strap, can also be used to link two separate amps. This way you won't need RCAs to the second amp and the levels will be matched. If you use RCAs you would have to gain match the amps. The owners manual would have this information.
Pioneer 80PRS
I was looking around on the C2 Audio facebook page, as I swear I saw something related to this on there a while back...
As the manual states ** Do NOT wire below 2ohm when strapped, could cause damage and void warranty**, well someone called them out because the picture stated 1 - 8ohms.. The owner then chimed in and stated they spent good money on making these amps fully .5 stable, so wiring down to 1 ohm when strapped is fine for these recon amps.
Thanks for the input!
F O.
Not sure what kind of crack we are smoking today boys but the OP has two subs and two amps. Wiring each D1 sub to each amp would be 2 ohms final on each amp. Yes, he has the option to wire at half per amp either but there's no need.
Here you go:
http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=1&I=12#results
Strap them at 4 ohms and use the input link.
Pioneer 80PRS
nah, they handle .5 just fine from what i have been reading..
"The amps are .5 ohm stable so strapped you can run 1 ohm total load. Each amp will see a .5 ohm load putting out max power (Although distortion level does increase over 1). I do not personally care for them at .5 but I did pay the extra $ for them to be fully stable at 1/2 so competitors had more versitility. If they drop below .4 they go to protect as they are designed to take a beating and keep working. SMD did some videos of this and he even was suprised durring torure test it did not kill the amp the torture test just kicked them in protect they always turned right back on." - Owner of C2 Audio.
Decided to just wire the subs together to 1 ohm and call it a day!
F O.
  • Who's Online   1 Member, 0 Anonymous, 1670 Guests (See full list)
