[email protected] Posted February 1, 2016 Report Posted February 1, 2016 i have 3 sundown sa12 d2 i am needing help making a box for them. i have a 2002 dodge dakota extended cab. the subs are being powered by a hifonic brutis elite 2100 watt amp. i would like to have all of the subs facing up. thanks
Triticum Agricolam Posted February 1, 2016 Report Posted February 1, 2016 Can you post the max dimensions of your space? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
[email protected] Posted February 1, 2016 Author Report Posted February 1, 2016 front to back 16in. wide 45in. tall 30in. those are my max dimensions i can do
MADVIBES Posted February 1, 2016 Report Posted February 1, 2016 here is a dakota I did with 3 15" bostwick subs. sounded wicked off 1200 watts DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
MADVIBES Posted February 1, 2016 Report Posted February 1, 2016 DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Joe X Posted February 1, 2016 Report Posted February 1, 2016 Here is a suggestion port either passenger's or driver's side, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 6", figure is just an assembly guide:
[email protected] Posted February 1, 2016 Author Report Posted February 1, 2016 i like the design. is that 6ft^3 after sub displacement?
Joe X Posted February 1, 2016 Report Posted February 1, 2016 Yes, after all displacements including drivers (net volume).
