RageQuitForLife Posted February 6, 2016 Author Report Posted February 6, 2016 Try unplugging your radio antenna. Ive seen screwed up ground messes already that go away as soon as the dang antenna is unplugged.. so am i unplugging the the am/fm wire from the headunit?
audiofanaticz Posted February 6, 2016 Report Posted February 6, 2016 Try unplugging your radio antenna. Ive seen screwed up ground messes already that go away as soon as the dang antenna is unplugged.. so am i unplugging the the am/fm wire from the headunit? correct. The antenna outer shield is ground/shielded, the inner tiny plug of it is the actual signal. Typically if you have noise, and unplug the radio antenna and said noise goes away it typically means the radios ground inside the wiring harness is not good or a poor connection.
