akuma4u Posted February 9, 2016 Report Posted February 9, 2016 Hey Im going to be running a 2krms amp + around 300-500 rms for mids/highs i have an agm under the hood and will have a g31 in the back.. i have a stock 110amp alt for how long will my alt be able to handle this set up? is it absolutely necessary to upgrade to a HO for this set up? Can i get by with what i got? thank you
Ahmed Johnson Posted February 9, 2016 Report Posted February 9, 2016 At full tilt, maybe a song or two as long as you don't come to a stop, lol
akuma4u Posted February 9, 2016 Author Report Posted February 9, 2016 At full tilt, maybe a song or two as long as you don't come to a stop, lol ah serious? so looks like i gotta play conservatively , go easy on the bass knob and volume, and recharge the trunk batt weekly..
B-Sh0t Posted February 9, 2016 Report Posted February 9, 2016 Just watch your volt meter, try not to dip below the resting voltage of your battery for too long and it wont be so hard on your alt. if your wired to 1ohm depending on subs and box you will be rising 2.5ohm or better.
ShadeTreeMechanic Posted February 9, 2016 Report Posted February 9, 2016 It will work just keep an eye on the volt meter in the dash. (if you don't have one then get one) when the needle starts bouncing with the bass then turn it down a little until bouncing stops. This will keep your alt at max output and will kill it sooner than normal. In the early 90s I had to replace my alt about every year. I had an alt with lifetime warranty and they lost money on me. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
akuma4u Posted February 9, 2016 Author Report Posted February 9, 2016 Just watch your volt meter, try not to dip below the resting voltage of your battery for too long and it wont be so hard on your alt. if your wired to 1ohm depending on subs and box you will be rising 2.5ohm or better. sorry for the n00b style but what does "rising 2.5ohm or better" mean? and yes i will be wired at 1 ohm on a crescendo amp
akuma4u Posted February 9, 2016 Author Report Posted February 9, 2016 It will work just keep an eye on the volt meter in the dash. (if you don't have one then get one) when the needle starts bouncing with the bass then turn it down a little until bouncing stops. This will keep your alt at max output and will kill it sooner than normal. In the early 90s I had to replace my alt about every year. I had an alt with lifetime warranty and they lost money on me. lol i have a volt meter on my tablet, there is no needle so i can not tell if there is any bouncing going on and its not the most accurate but gets the job done.. with my old set up which was 1200 rms or so.. it digital lcd meter would go down to the mid 13s sometimes a little lower then once i stopped the music or it went to an area where there was no bass it would go right back up to 14.1 or 14.2 with my new set up - i have no idea what will happen..
ShadeTreeMechanic Posted February 10, 2016 Report Posted February 10, 2016 Just member that when voltage goes down the amperage goes up as the amp tries to maintain output. This can be hard on an amp and charging system that can't keep up and hard on batteries with a high charge and discharge cycle. Putting it on charge will help. Next year when your alt dies then you can get an HO. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
akuma4u Posted February 10, 2016 Author Report Posted February 10, 2016 Just member that when voltage goes down the amperage goes up as the amp tries to maintain output. This can be hard on an amp and charging system that can't keep up and hard on batteries with a high charge and discharge cycle. Putting it on charge will help. Next year when your alt dies then you can get an HO. is it safe to say a good number to stay above on an average basis is 13.4 area? is i dip below that on a constant basis - i should be worried/concerned?
ShadeTreeMechanic Posted February 10, 2016 Report Posted February 10, 2016 A slight dip is ok just stay above 12v. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
