box build for four soundqubed HDC3 12 D2
mayday187
Need a ported box design for four HDC3 12 d2 to go in my tahoe. My max dimensions are 20" tall 48.25 wide and 32.25" deep. trying to keep box under my cargo cover. to be powered by 10,000 watt lanzar opt 110001d amplifier. anny help is appreciated.
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 5/8", figure is just an assembly guide:
Would this box size work for 2 hds 212 s? I want one that is this wide to fill between the wheel wells of my tahoe and possibly be able to add two more hds 212s and a.other amp to supply power. 99 tahoe
Ive been searching for days now and finding the right size up firing back port box for a tahoe has been frustrating. Used calculators and they tell me i want a small blx 30 invhes long instead of the 42+ i want .
The box is too big for two subs, wait to get 4 if using the above.
o im trying tp figure out the cuts for the port. I got the tops bottoms sides front and.back cut but not sure.om the ports. Is it saying it only goes 18and one sixteenth deep or 26.5 deep. The picture looks like it goes all the way to the bacj but then.how would that work
  • Who's Online   0 Members, 0 Anonymous, 6288 Guests (See full list)
