Sundown subwoofer advise
Jamesv
First time post, long time stalker. I've decided on sundown E series. I have a Rockford fosgate p500x1bd with a birth sheet of 802 at 1 ohm. This will be in a bmw 328, with a sold metal back seat(I might cut through though). I have about 3 cubes to play with and using aero ports due to space limitations. I would like 2 12" subs, but I'm short .5 cubes according to sundown. Would I be ok, or should I step down to 2 10" subs. Thanks for advise and input. Also building my own box, stepping up from a cvr12 and Sony amp. Not first build.
If you can fit the 2 10's then they will have more cone area then the single 12".
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
It was discussing two subs of either or. Not one 12 vs two 10s. That's why I wanted the two 12s, as big as I can get on surface area. But is it too small of cubes for two 12s?
Don't suffocate the 12s... Get two 10s
c-pillar flat wall 157.11db on music
2 crossfire 8k
4 NSV3 18s
4 crescendo 10s
4 Rockford pro 6.5s
Quad excessive amperage 350alts
4 juicebox 3100s
I'm was thinking that logically, but wanted the 12s. Should I keep it to 1cf per sub plus sub and port displacement then, or just build it to my max of 3 cf which would be more than enough to cover port and sub displacement? Thanks guys!
I just did an install for 2 DC lvl 2 12's on that BMW why are you short air space?
it slams to did not have to cut the metal back seat ether
it was very tight your measurements need to be spot on but should have no problems with 12's
I want to have access to the storage compartment in the trunk. So it's shallow enough to open the hatch. I still want to have usable trunk space, so have to compromise somewhere.
To get to 3 cubes, which the 2-12s require 3.5 cubes, I was going to glass the bottom of the box to stay with the curves of the bottom, and slant the back. It was going to end right where the trap door begins. This is in a sedan on an 07 model. Maybe the one u did has a different layout.
the DC's were under powered so I did a 3.25 cube box with access to all panels
IT IS RECOMMENDED air space not
the only size that will work
but go 10's obviously 12's is not going to work for you
  • Who's Online   0 Members, 0 Anonymous, 2356 Guests (See full list)
