dthomas Posted February 24, 2016 Report Posted February 24, 2016 I have a singer 270 alt with the blue transpo adj regulator. I have read on the forums that it can work with 2 alts. I have a excessive amperage 300 with a internal regulator. So I opened the cover and removed the internal regulator. I then spliced into the wire going to the singer and hooked it up the same way to the EA. With both hooked up I get no charge from either. If I unhook the ea the singer charges. Wondering if I missed something when removing the internal regulator. I just unbolted it and desoldered the one connection. Any ideas?
dthomas Posted February 24, 2016 Author Report Posted February 24, 2016 Forgot to add they are gm ad244.
dthomas Posted February 24, 2016 Author Report Posted February 24, 2016 After doing some more reading it looks like I may need a negative going to the ea somewhere. The singer has a ground connection.
dthomas Posted February 24, 2016 Author Report Posted February 24, 2016 After spending hours researching I think I figured it out. On the singer the bolt to attach the field wire had a plastic washer I believe to not ground the field wire since the bolt tightens into threads on the housing. I did not have one on the EA. To verify my idea I grabbed the internal regulator and sure enough it is just plastic on the top where the bolt tightens down, with a contact on the bottom. Going to retry tonight.
Tarball Posted February 24, 2016 Report Posted February 24, 2016 following CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Bump4life Posted February 24, 2016 Report Posted February 24, 2016 i highly recommend using 1 blue box regulator per alt. IT becomes less reliable when you run more than 1 alt on them. all you should need is the transpo on a relay that turns on with the car. then both alts gorunded to car, and a positve field wire going from regulator to one side of the rotor contact. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
dthomas Posted February 24, 2016 Author Report Posted February 24, 2016 i highly recommend using 1 blue box regulator per alt. IT becomes less reliable when you run more than 1 alt on them. all you should need is the transpo on a relay that turns on with the car. then both alts gorunded to car, and a positve field wire going from regulator to one side of the rotor contact. Thanks for the advice. I may pickup a 2nd one after getting this working. I have the regulator hooked up with a relay, and it runs the singer just fine. But it wouldn't run the EA by itself. So hopefully tonight when I put that plastic washer in, it will start working. I was pretty frustrated last night so I took them both out and just started going over everything.
Bump4life Posted February 24, 2016 Report Posted February 24, 2016 i highly recommend using 1 blue box regulator per alt. IT becomes less reliable when you run more than 1 alt on them. all you should need is the transpo on a relay that turns on with the car. then both alts gorunded to car, and a positve field wire going from regulator to one side of the rotor contact. Thanks for the advice. I may pickup a 2nd one after getting this working. I have the regulator hooked up with a relay, and it runs the singer just fine. But it wouldn't run the EA by itself. So hopefully tonight when I put that plastic washer in, it will start working. I was pretty frustrated last night so I took them both out and just started going over everything. it sounds like you are shorting the field on the one alt. hopefully the transpo is still fine. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
dthomas Posted February 24, 2016 Author Report Posted February 24, 2016 Last thing I did was make sure the singer was still working so I think the transpo is ok.
dthomas Posted February 26, 2016 Author Report Posted February 26, 2016 The missing plastic washer was the problem. Now both individually work fine and both together work fine.
