Using a DD-1 on a self powered home audio subwoofer
I had my dad pick up a B&W ASW1200 I believe it was. It is a 12" subwoofer with an attached 200w amplifier. On the amp there is a knob, can't remember if it was labeled as volume, gain, whichever. My question is. Shouldn't I be able to take the amp off, wire up the DD-1 to the amp and turn the dial until it picks up distortion, if there is any. I really believe the answer to that is yes, and if it is I have another question. I am not the best on knowledge of how the different db tracks work in comparison of each other. So in a home setting, where for the most part, is always the same constant voltage. What track would you use to tune a home audio subwoofer? Is it still based on the style of music that would be played through it to try and best match up what is played? Thanks in advance my bass heads.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
bump pl0x
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
The dd1 works up to 125v so you should be alright.
16 ohm load requires 56.6v to get 200w
8 ohm load requires 40v to get 200w
4 ohm load requires 28.3v to get 200w
2 ohm load requires 20v to get 200w
Going to guess that the woofer in there has either a 4 or 8 ohm coil which puts you well in the usable range of the dd1.
As for the test tone I don't know, so hopefully someone chimes in on that.
Thanks, never knew about that voltage part. I am pretty damn sure I can, just want to hear a yes it will work as it's meant to before I possibly harm his nice new expensive sub
Edited by RooTxBeeR
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I'd take the sub out, hook onto the amp outputs and try track 3(-5db) first. Toss the sub back in and listen to it, if that's not enough tho open it back up and move on to 5(-10db).
Play track 3,5 or 7 on test CD (Track 3 will ensure maximum sound quality, Track 7 will result in a louder system, Track 5 is a compromise). Your choice.
  • Who's Online   0 Members, 0 Anonymous, 1310 Guests (See full list)
