Box bracing identification
Totalnoob
PL 8x for adhesive, with lags.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Oh ok thanks guys i guess i will try out the floor flange way. After you guys thread in the flanges do you guys glue it or is it sturdy enough to just screw on and leave it? Also is there room for error when installing it because i would hate for it to be a bit too short. Also what bolts do you use to bolt it to the box?
how I've always done it with pipe is to put 2 flanges on each side of the panel on your box, and bolt them together. But like I mentioned, if you can't use any depth just get a piece of flat steel and drill holes where the holes are in the pipe flange and use that one the outside.
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
just to add to previous post... I would drill a hole in the parallel panels where the dowel would be placed.. and depending on strength/thickness of panels I'd cut the dowel about 1/8" or so bigger and ramming it into place then feed a little glue and screw the bad boy in...
  • Who's Online   0 Members, 0 Anonymous, 1366 Guests (See full list)
