no
Hammerdown... 1%
if the 2 enclosures are the exact same then you can wire them to what ever the coils can go to.... 4 X 2ohm can do either 2ohm, .5 ohm or 8ohm.... you would need 4ohm subs to do 1 ohm final or 4 x duel 2ohm
I have 4 12" Orion HCCA 2 ohm each. And an Orion HCCA 5000.1D amplifier. Thank you everyone. I will have to re think what I was planning.
yea... either new subs or run 2 amps.... might be better to downsize the amp and run 2 if the space is not a concern... maybe find someone with 2 smaller amps that wants to upgrade to a bigger amp... finding a .5ohm stable amp is a pretty expensive task
Thanks everyone for the help.
Does anyone have any suggestions on enclosure ideas for what I have?
Are they DVC? If they are, yes it's possible.
Yes, they are DVC. Orion HCCA Subwoofer 12" DVC 2 OHMS
If it's possible, could you explain how I would be able to do it?
  • Who's Online   0 Members, 0 Anonymous, 1356 Guests (See full list)
