Masterbasser Posted March 8, 2016 Report Posted March 8, 2016 Well I picked up another atomic 5000.1 for new build (just in the material collecting phase as of now) I have a mechman 320 in the car now and no one makes a bracket to run more then 1 alt stage 1 -So for the sub stage I have 2 atomic 5000.1d and 2 soundqubed hdc4, the plan so far is to run an amp on each sub which will be around 1.6ohms on each amp. what kinda amp hours would I need to support both these amps at 1.6 ohms each? down the road I will maybe get fi team 18s and run the amps at 1 ohm each Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
shogen Posted March 8, 2016 Report Posted March 8, 2016 Well I picked up another atomic 5000.1 for new build (just in the material collecting phase as of now) I have a mechman 320 in the car now and no one makes a bracket to run more then 1 alt stage 1 -So for the sub stage I have 2 atomic 5000.1d and 2 soundqubed hdc4, the plan so far is to run an amp on each sub which will be around 1.6ohms on each amp. what kinda amp hours would I need to support both these amps at 1.6 ohms each? down the road I will maybe get fi team 18s and run the amps at 1 ohm each good plan.... what coil config you have on those subs? Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
Masterbasser Posted March 8, 2016 Author Report Posted March 8, 2016 they are dual 1 ohm but read around .8 per side with a cpl different multimeters Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
ChevyBoy95 Posted March 8, 2016 Report Posted March 8, 2016 Probably stock battery upgrade plus 5-6 group 31's, and that should keep up well when you go to the full 10k (wired at 1 ohm per amp instead of 1.6). Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
