how much juice would I need for...
Well I picked up another atomic 5000.1 for new build (just in the material collecting phase as of now)
I have a mechman 320 in the car now and no one makes a bracket to run more then 1 alt
stage 1 -So for the sub stage I have 2 atomic 5000.1d and 2 soundqubed hdc4, the plan so far is to run an amp on each sub which will be around 1.6ohms on each amp.
what kinda amp hours would I need to support both these amps at 1.6 ohms each?
down the road I will maybe get fi team 18s and run the amps at 1 ohm each
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
good plan.... what coil config you have on those subs?
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
they are dual 1 ohm but read around .8 per side with a cpl different multimeters
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
Probably stock battery upgrade plus 5-6 group 31's, and that should keep up well when you go to the full 10k (wired at 1 ohm per amp instead of 1.6).
  • Who's Online   1 Member, 0 Anonymous, 500 Guests (See full list)
