Enclosure Design
Thizz719
Need help with a vented enclosure for two 12" Rockford T1D212 my max space is 16 1/2 H x 36" W x 36" D I'm gonna run them on a Rockford T1500-1bdcp with 1/0 gauge wire 200 amp and the big 3 and 8 gauge speaker wire if anyone has enclosure designs or would like to help
So you have 10 Cubic Feet of space and only need 3.5. how would you like them to fire? (Subs up port back) (Subs facing back info like this would really help)
EDIT: Try this --->
EDIT: Try this --->
not enough port.
Also those subs are better suited for a sealed box.
Friend of mine has same subs in this box they sound good.. and I know they are better in a sealed box but he wants a ported box "Need help with a vented enclosure"
With only two 3" ports that box posted a picture of might as well be sealed.
Builds:
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Hello I need some help and dimensions of a box design for 2 15 inch L7 subs to be at 27 to 29 Hz please and I been looking every where for the right box to build ?
Once again Mr. Knowitall shows up to talk down one someones ideals but has none of his own..
Make a thread mentioning vehicle and amp models and max dims for a box.
  • Who's Online   0 Members, 0 Anonymous, 3018 Guests (See full list)
