I thought I couldn't do it but I made it happen. Pulled out the old yellow top and dropped in the D3100. I was gonna lay the battery down on its side but Dmanson stopped by and convinced me to at least try to set it up right. I removed the yellow top and stock battery tray and it sat it there. I added a Summit Racing battery tray and bolted the tray down to make sure this monstrosity of a battery doesn't move.
Here's pics of the old yellow top and how small it is compared to the D3100
Here's pics of the D3100 sitting under the hood. Since it was a tight fit I put electrical tape over the positive terminal but if you notice the 0/1 gauge wire going into the ring terminals sit up higher than the Powermaster terminal and it does not touch the hood. I still want to find some type of plastic piece to cover the terminal tho.
Once I was finished installing the batts I was chilling and drinking a beer and then the doorbell rang. It was the mailman with my missinglink module. So I was like what the hell. Went out and installed it. Pretty straight forward. This thing takes more time tying down the wires than it takes to install to the alt wire. Very good product.
Here's the module
Check out what the voltage is sitting at. Gotta love it.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
FUCK!!! These powermaster batts aint no joke!!! I cant wait till i have my 96' impala runnin these batteries fareal!!! Im jealous of you guys!!
ACT YOUR AGE AND NOT YOUR SHOE SIZE
i gotta get my weight up and get me that misslink module
Edited by dmanson
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
What was your voltage at before the module?
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
Before the module I would sit at 14.3 - 14.5 depending on the temp.
now get back out there and put that 2nd D3100 in ...........
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Boy you wild!!!
Another one will fit between the frame rails behind the front bumper, that is where my HC2400 is. Build a bracket out of angle iron and you are set. Keeps more room in the back for equipment.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
  • Who's Online   0 Members, 0 Anonymous, 3616 Guests (See full list)
