J_west07 Posted March 20, 2016 Report Share Posted March 20, 2016 I've got a MB quart da-3000 and I was running it at .5 ohm (I know not suppose too) and it never got hot or smelled like smoke or anything and its cutting on and off. It was play sometimes and other times it won't even come on. Sometimes it will come on and just won't play anything. I've wire my sub about to 2ohm. Figuring I've prob already fucked the amp but I figured I'd ask and see if there is a way to check. Read about alot of people running them at .5 ohm that's why I did it. But I guess that's just all Internet talk...... Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 20, 2016 Report Share Posted March 20, 2016 Its like a lot of things. Just because you can doesn't mean you should. Maybe try running it off of the rear outputs from your deck. There is a slight possibility your sub out might be going bad. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
3vil Posted March 20, 2016 Report Share Posted March 20, 2016 Also check the ground. Running at .5ohm is stressful and if the ground is dirty/loose the amp will think it's seeing low voltage. Link to comment Share on other sites More sharing options...
J_west07 Posted March 20, 2016 Author Report Share Posted March 20, 2016 I'll try switching the outputs but like right now the power light is flicking on and off..... Yeah my ground is good for sure ran a ct3k at .5 ohm from this ground Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 20, 2016 Report Share Posted March 20, 2016 Double check all of your power connections. Maybe the remote turn on is intermittent. Other than something simple it is probably toast as well as a fire hazard. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
im_quagmire Posted March 20, 2016 Report Share Posted March 20, 2016 MB QUART? .5 OHM? CHANCES ARE THE INTERNALS ARE FRIED. LOAD THE AMP TO ITS RECCOMENDED IMPEDANCE AND HAVE IT CLAMPED TO SEE WHAT WATTAGE IS BEING PRODUCED. IF IT IS SIGNIFICANTLY LOWER THAN RATED, OR NOT PLAYING AT ALL, YOU HAVE ISSUES. But What Do I Know? 2003 Chevy Monte Carlo SS 3.8 JVC KD-R975BTS Clarion EQS746 Kenwood P907PS Ascendant Audio 12" Havoc v.1 Ampere Audio 2000.1 MB Quart Onyx 800.4 XS Power D3400 - Hood XS Power D975 - Trunk Singer 240A Sky High OFC 0 & 4 gauge Kno Knoise Kolossus Deadener Link to comment Share on other sites More sharing options...
