Jessica Posted May 27, 2016 Report Posted May 27, 2016 230 amp alt and 2 batteries with a 1200 watt amp, I doubt you will even see a dip in voltage. Your friend is an idiot Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
reedal Posted May 27, 2016 Report Posted May 27, 2016 Between the supercaps and the NVX cap, the supercaps would be more beneficial I think, as most of the consumer oriented car audio capacitors aren't worth much at all. But neither are needed in my opinion. It's a low-power/low-current draw system, with a good sized alt to power it without any issues. If he wants to have more reserve capacity on tap, then I'm sure there's plenty of room under the hood in that old truck to add a second battery tray for another optima. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Jessica Posted May 27, 2016 Report Posted May 27, 2016 if you run the NVX, make sure its very close to the amp, less than 6". It will give you the most benefit that way. Not that you need it. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
