P33BL3S Posted March 27, 2016 Report Posted March 27, 2016 How accurate is the sub box calculator on the12volt website? reason im asking is i have had pretty good luck with designing basic boxes on there. but i am currently walling off my buddies car. well more like a sealed off trunk build. and im having doubts about the port. dimensions of the box are Width: 29" Height: 13.5" Depth: 24" Wood: 1" mdf Now for the port he wanted to have it tuned around 38hz. so according to the site the port is 11" tall 1.5" wide and like 4" long. dont remember the exact measurements on the length. but we got it all cnc cut and i wanted to make sure before continue. its for 2 alpine type R 12s on 2 rockford BD1000. after displacement the box will be about 2.8 cubic feet i believe
ShadeTreeMechanic Posted March 27, 2016 Report Posted March 27, 2016 The area of the port sounds small to me. This would make the port look short. Also I think 38hz is a little higher than most people would tune to. This will make it look shorter too. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
P33BL3S Posted March 27, 2016 Author Report Posted March 27, 2016 im just doing what he asked, my car was tuned to 35hz he liked it but wanted to go to 38hz. but we can adjust the port tuning before i 100% complete the box incase he wants it tuned lower
Joe X Posted March 27, 2016 Report Posted March 27, 2016 You will need some 60 square inches of port area, two cubic feet net per driver for the old 1243s or 1.5 to 2 net for the new ones, also you don't need 1" MDF for those subs, 0.75" would be fine and your box would be quite a bit lighter and cheaper to build.
