Oneslowmonte Posted March 29, 2016 Report Posted March 29, 2016 I'm kind of curious if I dug myself into a hole. I'm trying to fit 2 hdc3 15s in my 06 monte carlo by sealing off the trunk. I came up with the dimensions as following Height 18'' Width 37'' Length 26'' After displacement would be around 8.11..?? My first time figuring this out. The subs are 15.5" wide so I'd be kind of tight for Aero ports wouldn't I? Was planning on using a kreg jig to assemble in the trunk since it seems the easiest way to go from my research so far. If anyone could drop some knowledge if I'm going the correct route would be greatly appreciated!
Triticum Agricolam Posted March 29, 2016 Report Posted March 29, 2016 How much power are you going to be running? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Oneslowmonte Posted March 29, 2016 Author Report Posted March 29, 2016 I have a hifonics 3216.1 right now with a 300 amp alt. Gonna get a battery next week as well to replace the stock one.
rockFord_Expedition Posted March 29, 2016 Report Posted March 29, 2016 Mock everything up with cardboard. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
Oneslowmonte Posted March 29, 2016 Author Report Posted March 29, 2016 Mock everything up with cardboard. Will do! I'll have my buddy snag some from work and see how it goes.. Looking at measurements trying to figure it out is driving me crazy
MADVIBES Posted March 29, 2016 Report Posted March 29, 2016 I did a system that had 3 15" subs in a monte, I did a 4th order with the port blowing up through the rear deck, sounded great for 3 w6 15" subs, of course this was 2003 or 4 i think. when the subs were still black and made in the USA DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
Oneslowmonte Posted March 29, 2016 Author Report Posted March 29, 2016 I did a system that had 3 15" subs in a monte, I did a 4th order with the port blowing up through the rear deck, sounded great for 3 w6 15" subs, of course this was 2003 or 4 i think. when the subs were still black and made in the USA You have any pics of that by chance? I was curious about facing them up and doing that as well. Not sure how it would sound since everything I've ever had has been prefab set ups lol. Been searching and everyone says to seal the damn trunk off. I just had to buy 15s smh! Those jls need a ton of airspace too?
Oneslowmonte Posted March 29, 2016 Author Report Posted March 29, 2016 I did a system that had 3 15" subs in a monte, I did a 4th order with the port blowing up through the rear deck, sounded great for 3 w6 15" subs, of course this was 2003 or 4 i think. when the subs were still black and made in the USA You have any pics of that by chance? I was curious about facing them up and doing that as well. Not sure how it would sound since everything I've ever had has been prefab set ups lol. Been searching and everyone says to seal the damn trunk off. I just had to buy 15s smh! Those jls need a ton of airspace too? Now that I've seen some pictures of 4th order boxes I'm gonna have to look into that lol
hdorre Posted March 29, 2016 Report Posted March 29, 2016 you have 8 cubes, assuming youre doing a single layer box with a double baffle. Factor in sub disp, and youre looking around 7.6 cubes. With a decent port, lets say that eats up 3/4 of a cube. Without any bracing youll have near 7 cubes net, but possibly a bit less. As for port area.. if its forward facing, your max height is 16.5 (with a slot). Absolute max port width is 5.75", but i dont like playing THAT close. lets say 5.25" of width. Basic multiplication gives you a max port area of ~86sqin. This *could* work, but itll be tight, in almost every possible way. Another thing to consider is actually fitting your box into the trunk opening. Many times, the opening is less wide and shorter than the actual trunk. As a result, you may need to either build in the trunk (kreg jig is sex) or cut down on dims somewhere. Unfortunately, you really cannot cut down on space. My advice is to invest in a chiropractor, once this build is complete. Good luck On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
MADVIBES Posted March 29, 2016 Report Posted March 29, 2016 unfortunately I did not take any pics of that set up, it was pre smart phone so I usually just wanted to get jobs like that outta the way. you could even face subs forward and port up through the rear deck. That is always a possible solution, thats how I had my car for the longest and always had good numbers. there are so many possibilities with your system I am sure you are going to get a lot of good advice on here all with different ideas play around and find what works best. Its a race won by slow hard work not a sprint. DB DRAG PSYCHLONE PRO 156.3 30 SECOND AVERAGE FO MAX AT 26HZ LEGAL DASH DRIVER DOOR OPEN 158.0@30 HZ MY BEST SO FAR, HOPEFULLY A 160 COME FEBUARY. 156.9@26hz 158.0@30hz
