The Loudest Coax Speaker? Maybe......
Lol. Yeah i would guess 1k is slightly optimistic. Just slightly. Lol. If I had a true 1k I would try it. Stay tuned.
Pioneer 80PRS
Does anyone know what the true output of the inuke 6000 four channel is? Has anyone seen one on a dyno?
Pioneer 80PRS
Interesting. Thinking of getting a couple myself
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Yours look to be in a sealed enclosure, is that what you would recommend? Good midbass out of them being 10" and in a sealed?
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I am not sure what size my boxes are. They are standard truck boxes for behind the seat. I am using the amp cross over at 100hz. What I would do is build a box using the ts parameters. I would probably do it sealed to make it easier to blend with the subs.
Pioneer 80PRS
I just went out to the garage to measure the boxes. They are about 1 cubic foot each. I found the empty boxes they came in and they make no recommendation to box size or even hint at the T/S parameters. This is basically a big mid range / horn tweeter combo that is listed to play 80hz to 22khz. The mid bass output I would say is typical for a 10 inch mid bass. I found the T/S for the 10" without the tweeter. In a sealed box with a Q of .7 for a flat response, it calls for a box of 1.1 cubic feet. This gives a resonant frequency of 84hz and a 3db down point at 85hz. I don't know if it would be the same for the coax, but they sound good to me in 1 cube each. Hope this helps.
Pioneer 80PRS
I got 4 of these coming, saved an extra 5 bucks for buying more than 3, lol
I looked at these as well but ended up going with the exact ones you have with the compression horn tweeter =/
http://www.lanzar.com/sku/OPTI1024/Opti-Drive-Pro-10-Coaxial-Full-Range-4-Ohm-Subwoofer
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Cool! Four of those will definitely get loud. The ones in the link look similar but have a dome tweeter instead. The power handling is less and the voice coil on the mid is smaller. I am happy with the horn tweeter and I'm sure you will be too. I am looking forward to seeing more pictures of your build.
Pioneer 80PRS
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
I just got my 8 inch pair for my truck. I will post pictures soon.
Pioneer 80PRS
