JBL GT5-10D or JBL GTO1014D
The GTO1014 is the better sub. Cast frame, higher power handling, etc.
Builds:
The GTO is the higher of the 2 lines , cast frame and the coil is slightly longer on a heavier aluminum former if I remember correctly , both are great little subwoofers , that have good output and good SQ
so i should get the GTO1014D?
Yes are a little better and at $25 each you can't really hurt yourself. If you have a similar deal for 12s and you don't mind a somewhat larger box I would go for that as you will get much better output for the same power.
  • Who's Online   1 Member, 1 Anonymous, 553 Guests (See full list)
