What size aero though?
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
What amp are you going with? The amount of power will determine what the cross section of your port will need to be. The length will be the result of cross section and tuning frequency.
Pioneer 80PRS
OK, well lets assume you are going to do like most and put a bit more than RMS power to those subs. Say 2,200 watts. So 2,200 watts into a ~2.7 cube box at 39 Hz I'd use 50 sq in of port area. That should keep your port velocity at or below 30 m/sec.
FYI, wouldn't try putting more than 2200 watts to those four subs are you will likely run into excursion issues. A lower tuning would help, but your port will get to be pretty long.
Builds:
So 50 sqin would be an 8 inch aero? Or could a 6 inch work because it is flared?
Pioneer 80PRS
8 in aero is 50 square inches roughly. 6 in aero is only 28ish. I'd go with the 8. Flares don't make a difference when determining port area because the main chamber the air passes through is where you take your measurements from iirc.
Subs/Amps: TBD
