Battery bank charging q.
Ok so should i use the recondition mode on my batts after i fully charge them ? Ive never ised that mode just the snow flake / agm charge mode. I wanna make sure im taking good care of my batts thanks for yalls in put in advance. ( using ctek 7002 charger)
12.6 and higher is a fully charged battery. Most "smart" chargers go into trickle mode after they are charged. If ur 12.6 or more i wouldnt worry about reconditioning, most people select that if the battety has been drained down past 12 volts, after its been "reconditioned" then its trickle charged and ur done.
To properly charge and load test batteries its best to do them individually. But it appears your batteries are ok from what you said 12.78 or so.
Well i topped off my batts and there resting at 12.82 so im satisfied with that. Thanks for the input. Im going to add a couple more hrounds that ive been meaning to do maybe that will get me a better charge on my batts
on the Ctek charger you canuse the recondition mode if that batteries have been sitting idle for awhile. otherwise charge them like normal and they should be good to go
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
