Subwoofer Enclosure for 2 Rockford Fosgate P3 15's
05F15DY
I need a ported box design for 2 Rockford fosgate p3 15's that is 6 cubic foot and tuned to 32 hz after displacement. These will be going into an extended cab 05 f150 and will be powered at the rated rms power which is 1200 watts. All help and input will be appreciated. Thanks.
Ok you will need to remove the backseats for this, if done so measure max dimensions for a box (height, width, depth).
So here is your request, port firing passenger's side is suggested, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/2", figure is just an assembly guide:
How big should I make the "box support" piece, and what should it be made out of.
Use a hardwood dowel at least 1-1/4" in diameter.
Builds:
Should I put the dowel over the top edge of the port, and does it go all the way across the box. Sorry for all of the questions, just want to make sure I get it right the first time.
  • Who's Online   0 Members, 0 Anonymous, 1269 Guests (See full list)
