Sweety Posted April 14, 2016 Report Posted April 14, 2016 Hi guys, I really need some help in designing a 3.5 - 3.7ft^3 slot port enclosure for my Son's car. The subs are 2 JBL GT3 12" & max width is 36" max height is 16" & depth isn't an issue & he wants the slot port in the centre with the subs either side of it & tuned to 32-33Hz. I would have been ok if he wanted tube ports but I am getting lost with the maths trying to work it out for a slot port Many thanks in advance for any help
Triticum Agricolam Posted April 14, 2016 Report Posted April 14, 2016 How much power is going to be used? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Sweety Posted April 14, 2016 Author Report Posted April 14, 2016 How much power is going to be used? Each sub will see 240w RMS
Sweety Posted April 14, 2016 Author Report Posted April 14, 2016 Tried to do a little sketch but have a feeling my maths are out or i've messed up when it's came to the port
Joe X Posted April 15, 2016 Report Posted April 15, 2016 So here is a something very close to what you show (which would work in a trunk car), use it to build or to check your calculations, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Sweety Posted April 15, 2016 Author Report Posted April 15, 2016 So here is a something very close to what you show (which would work in a trunk car), use it to build or to check your calculations, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Thank you very much for all your help Joe X you have helped save me from a few more grey hairs or from going bald from pulling my hair out haha. Just need some fair weather now to get it all cut & built
