so folding the seats down helps? ill have to try that tomorrow
you would be surpised at all the little stuff that helps...closing vents, playing with the arm rest position, seat positioning....tons of variables that could either hurt or help your score when changed...
i likes me some audio stuff...
someone was sayin to me dont run your system till the contest. to keep batts charged.. thats about i all i know
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
heating up the coils on the subs will make them less efficiant. also make sure that the inside air /outside air switch on your vents is closed... remember you dont want airleaks in your car. is it b drag or usaci. if it is usa u can open your driver window about half way and that could add a little.
just remember that all these are helpfull (sometimes with some cars) ask around for help from veterens that are running the same type of vehical and see what tripcks they have found. good luck
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
My tip would be let your subs cool and dont play them before the comp and let your batts charge. A charger overnite and nothing to drain the batts before the comp.
Already had said it. Cooler subs and cooler amps and fully charged batts with higher voltage gives you more power and higher score! :)
i was on another forum and they said if i took some space up in my box to give me a lower ft^3 that that would raise my tuning and that might help. does anyone know a good way to take up space in a box thats easy to get out
i got second place with a 146.1 i got beat by a guy in a crx with 4 10" dd's im not sure what model they had the yellow cone and 2 4 thousand watt hifonics amps. he hit a 158
He had a CRX, DD subs, and 8k watts. :lol:
Don't feel bad.
I hope I at least tie my buddies score when I get metered in July.
138.5 on a burp at 50 some odd hz.
2 15" Audiopipes
Lanzar 4000w Vibe series
Pre-fab box
'94 Explorer
i dont feel bad it was crazy lookin he had a sub on top one on the driver side and two in the front of the box and he had a external areo port that looked to be as big around as his subs
